I have a Cisco PIX 501.....logs on the proper ports....can it be configured to work with RTM?
A different router
This topic is closed.
cborodTags: None
Hi,
You will need to download the Router Logger application in this thread and let it run for 10-15 minutes.
Here is the router logger application:
http://board.homeseer.com/showthread.php?t=106905
Then once you have your log file, please attach it to this thread (please make sure you indicate the name and model of the router)
http://board.homeseer.com/showthread.php?t=106906
I will then create a parser for it and put out a new version of the plugin so that you can use it with your router.
If you have any questions let me know
cborod
Update: Downloaded the utility.......can't seem to get the PIX to log properly to anything.....except my syslog server. Then that work thing keeps getting in the way. I'll be at it again this weekend......thanks for the patience! and helping hand. ChrisB
mlail
mlail
