Further Development?
This topic is closed.
jtwolf76
jtwolf76
update
I seen a post a while ago that new things are coming I was just looking for the details. (what will be the changes and when should I look for it)
jtwolf76,
The new stuff is: a new configuration and album art. Both still need a little work, but its getting better. Dale may have some other things in the works that I don't know about.
rascasse,
I know this can be done with scripting commands. Look in the HS2\Docs folder for an old help file named "SeerAMP.hlp" Please keep in mind this file is old and needs some updating. There is a list of commands for everything. Myself, I am very weak when it comes to scripting.
The ability to access the winamp library would be a nice thing to have to.
A virtual DJ mode, where the name of the tracks are announced before they play.
I need to test this Virtual DJ thing, and I know it can be done with a one-liner.
Rick
To add a "Virtual DJ" event, please use this script in an event triggered by Song Change:
&hs.Speak "Song has changed to " & hs.Plugin("SeerAMP").GetID3Info(0, 2) & " by " & hs.Plugin("SeerAMP").GetID3Info(0, 0)
This command will grab the song title (2) and the song artist (0) from the first instance (0).
API Specifications of GetID3Info:
Procedure: GetID3Info
Type: Function
Definition: Function GetID3Info(ByVal intUseInstance As Integer, ByVal intInfoType As Integer) As String
Input: (Integer) Winamp instance to perform action upon
(Integer) Type of information to get from ID3 tags (see list below)
Output: (String) Information retrieved from ID3 tags based on specified info type.
Description: Used to retrieve information from the ID3 tags of the current song.
Info Type List:
ID3_TYPE_ARTIST = 0
ID3_TYPE_ALBUM = 1
ID3_TYPE_TITLE = 2
ID3_TYPE_GENRE = 3
ID3_TYPE_TRACK = 4
ID3_TYPE_YEAR = 5
ID3_TYPE_COMMENT = 6
ID3_TYPE_PICTURE = 99
ID3_TYPE_PICTURE_HASH = 100
