After some setup problems with which Stipus helped me out (thanks, with the Interop.SpeechLib.dll it works), I would like HS to run a script when I make a phonecall myself, for instance put the dialed number with the time in a log file.
But HS doesn't seem to respond on the event.
I set it the Current trigger Type to "SIP Line" and the event to "Outgoing call". The action is running a script but for testing it doen't realy matter, when HS doesn't respond at all when a call is made by me.
What could I be doing wrong here?
