BETA Release 1.1.0
This topic is closed.
    BETA Release 1.1.0
    BETA RELEASE 1.1.0
    - Create Devices Function Much Faster
    - Max Volume Lockout Per Zones are now there own Devices(No longer on the config Page)
    - Added an adjustable send Delay(On the Config Page)
    - Multiple Receivers Now Work Correctly
    - Auto Reconnect of Receiver(Will Auto Reconnect, Send all Pending Commands, Then Poll Receivers)
    - Create Device Function to Find Current State of Receiver so it can be returned after Create Device Function is Complete
    I've complete rewritten the plugin. Some installation notes
    After installing the Power Device Control Will not work correctly, you must delete all power device controls, and re run the Create Devices Function
    Please report Bug,
    -Tom-
    -Tom-
    I'm assuming no problem yet? How about and pros or cons? If the version seems solid ill submit it to the homeseer updater, Thanks
    -Tom-
    -Tom-
      Hi, Directly after the reciver is powered on the logg is growing. Don't matter if the receiver powered on with homeseer or unit ON/OFF-button.
      PHP Code:
      2010-11-08 20:42:10  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:11  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:12  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:12  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0)
      2010-11-08 20:42:13  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010
      -11-08 20:42:14  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:14  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010
      -11-08 20:42:15  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:15  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:16  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010-11-08 20:42:17  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0
      2010
      -11-08 20:42:17  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45however max allowed is(0o
      2010-11-08 20:42:18  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:19  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:20  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:21  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:22  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:23  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:24  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:25  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:26  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:27  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:28  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:29  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:30  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:31  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:32  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:33  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:34  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:35  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:36  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:37  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:38  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:39  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:40  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:41  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:42  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:43  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:44  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:45  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:46  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:47  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:48  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:49  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:50  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:51  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:52  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:54  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:55  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:56  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:57  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:58  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:42:59  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:00  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:01  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:02  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:03  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:04  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:05  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:06  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:07  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:08  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:09  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:10  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      2010-11-08 20:43:11  TWA_ONKYOINTEGRA  Receiver 1 Volume on Zone 2 Attempted to be turn to level(45) however max allowed is(0)
      Tasker Plugin / Speech Droid
      Tonlof | Sweden
        TX-NR5008 receiver
        i just start with your Plug-in this weekend with the ver. 1.0.1.3, it did create the devices.
        Then I upgrade for ver. 1.1.0.0 and the create devices do not work any more.
        11/8/2010 4:49:28 PM - TWA_ONKYOINTEGRA - Receiver 1 Please Wait.....
        11/8/2010 4:49:54 PM - TWA_ONKYOINTEGRA - Receiver 1 Checking for valid commands, this process may take upto 10 minutes, please dont touch your receiver or shutdown Homeseer
        11/8/2010 4:49:54 PM - Error - GetDV DE error, Object reference not set to an instance of an object., Scheduler
        11/8/2010 4:49:54 PM - TWA_ONKYOINTEGRA - Done Sending Commands to Queue
        Don
          I also have problem to send command from events after upgrade/reinstall.
          No problem from HS status view to send on/standby.
          Non working:
          Device Command: TWA_ONKYOINTEGRA Power Control Value Set set to Power Standby
          Device Command: TWA_ONKYOINTEGRA Power Control Value Set set to Power On
          All others like volume, inputs is working.
          Device Command: TWA_ONKYOINTEGRA Input Value Set set to CD
          /Thanks
          Tonlof | Sweden
            Don
            Dont mind the the two errors.. the create devices function is still operating. To double check you can turn on debug mode, but it should still be working, the errors will be fixed next version
            -Tom-
            -Tom-
              PHP Code:
              2010
              2010
              2010
              The receiver is trying to adjust the volume level of zone 2 because you have the max set at level 0 but the zone 2 volume is set at 45. However the plugin can not adjust the volume because the power to zone 2 is off and is going into a loop. I will fix this in the next version but a quick fix would be to either turn on zone 2 or adjust the max volume for zone 2 to past level 45
              -Tom-
              -Tom-
                Non working:
                /Thanks
                you may have to go into the event and edit the event and resave it since those devices changed in this version
                -Tom-
                -Tom-
                  Once all issues are resolved i intent on adding many more devices
                  -Tom-
                  -Tom-
                    Hi Tom
                    I haven't had chance to try the new version yet as I am on the road but you mentioned you can delete devices how do I do that?
                    Just wondered if I delete all my devices and start a new create devie it might pick up more inputs etc? It must store them somewhere because even after a fresh install of Homeseer it found them all and whenever I create devices it just tries to find Zone 3 which I dont have and I get all the "Cannot create device" in the log.
                    Apart from no inputs it seems to work alright good work
                      Originally posted by b2cub View Post
                      Hi Tom
                      It only tries to find devices not yet created, You should have inputs, just try deleting your input device.. All you have to do is check the box next to the device and then at the bottom you can select delete from the dropdown
                      -Tom-
                      -Tom-
                        Non working:
                        /Thanks
                        Found the issue, will be fixed next version, it was an issue with power control, mute, speaker a, speaker b
                        -Tom-
                        -Tom-
                          BETA 1.1.1 Released
                          -Tom-
                            Originally posted by twa8000 View Post
                            BETA 1.1.1 Released
                            It's solved my problem. You are fast, thanks
                            Tonlof | Sweden
                              No problem, Thanks, Let me know if there are anymore issues i want to make sure it works for everyone, especially the people that were have issues with TCP/IP
                              -Tom-
                              -Tom-
