Hello,
I love the plug in, thanks for writing it. I just bought it.
My question is do you know how many IP controllers can connect to the AVR at one time?
I am trying to integrate another control system - a Universal Remote Control KP4000 with an MRX1, while coexisting with your plug in.
I did a test with your plug in, along with the Onkyo AVR iPhone app, and they both worked perfectly. If I touched a button on the iPhone app, your plug in would update. If I controlled via your plug in, the iPhone would update almost instantly.
So my conclusion is apparently I can have at least 2 connections via IP at the same time, however when I try to connect via the URC KP4000, it says all 2 way connections are in use. I am wondering if the iPhone is doing something special or reserved, and only one other 2 way IP controller can be connected?
I would try to do everything in HomeSeer, however there is not a good option for a touch panel that fits into a double gang J box, thus the need for the URC KP4000 in the wall.
I tried contacting Onkyo tech support, and talked to a guy named Darvin, but he did not know.... He said I needed to contact my dealer!
Thanks for any help.
Travis
Travis
