Hi Tom,
Is there a way of connecting to my amp with RS232 and still be able to still use the plugin,or is it going to be a case of once the plugin is connected, then the port is always going to be busy?
What i would like to do is send the amp via homeseer scripts the RS-232 command that your plugin does not seem to pick up on, i.e some of the sound modes, also there seem to be a lot of wrap-around code that would prove useful
looking at the RS-232 command sheet there is lot of command that could be sent via RS-232, But i do like the status update that you get with the plugin, like volume upated etc..
I have attached the latest RS-232 codes I could find, allthought it doesn't mention my amp, presume they are going to be very simular, chances are you will probably have this already
http://www.filesonic.com/file/145596...CVR_071509.xls
Steve
Steve
