I'm hoping there is a simple fix for this issue that I am overlooking. I have installed the TWA-Onkyo / Integra Plug-in with Homeseer Pro via a dual head USB serial adapter. I have confirmed that the serial port is active by shutting down HSPro and opening two serial terminals to their respecitve ports (same speed, parity, stop, and flow control). When I type text in one terminal I see it in the other and visa versa. I have also verified the pins of the serial cable are connected correctly.
The best I can tell, the plug-in is unable to communcate with my Onkyo TX-SR806 (Firmware version 1.06/08Z06B) via serial communication. I setup the plugin for Com 11 and turned on debug then clicked on discover. Currently my HSPro box is pegged at 100% utilization and has been slowly failing on each command. This has been going on for the past few hours. Another interesting obersvation is that I can not communcate or see any replies when I connect using Hyperterminal (9600, N, 8,1,No Flow). I have included sections of the log below in hopes that someone can give me an idea on how to make it work.
3/26/2013 2:06:48 PM - Startup -
3/26/2013 2:06:48 PM - Startup - ************************************************************ ********************
3/26/2013 2:06:48 PM - Startup - HomeSeer version 2.5.0.79 Starting Now (PRO Build)
3/26/2013 2:06:48 PM - Startup - Using system's regional settings
3/26/2013 2:06:49 PM - Startup - Creating Class Objects...
3/26/2013 2:06:49 PM - Startup - COM port classes started.
3/26/2013 2:06:49 PM - Startup - Application interface class started.
3/26/2013 2:06:49 PM - Startup - Web server class started.
3/26/2013 2:06:49 PM - Startup - E-Mail SEND class started.
3/26/2013 2:06:49 PM - Startup - E-Mail RECEIVE class started.
3/26/2013 2:06:49 PM - Startup - Z-Wave class started.
3/26/2013 2:06:49 PM - Startup - Plug-In Interface class started.
3/26/2013 2:06:49 PM - Startup - Speech recognition class started.
3/26/2013 2:06:49 PM - Startup - HSPhone dialer class started.
3/26/2013 2:06:49 PM - Startup - Loading Settings
3/26/2013 2:06:49 PM - Startup - Settings Loaded.
3/26/2013 2:06:49 PM - Startup - Current sunrise/sunset values calculated.
3/26/2013 2:06:49 PM - Startup - HSPhone external interface class started.
3/26/2013 2:06:49 PM - Startup - Local voice recognition class started.
3/26/2013 2:06:49 PM - Startup - Database SAVE process started.
3/26/2013 2:06:49 PM - Startup - Loading configuration file ...
3/26/2013 2:06:50 PM - System - Loading device types file...
3/26/2013 2:06:50 PM - Database - Opening (Mode=Read) up HomeSeer database: C:\Program Files\HomeSeer HSPRO\config\sample.mdb
3/26/2013 2:06:51 PM - Database - Loading Devices...
3/26/2013 2:06:52 PM - Load Config - 133 total devices loaded.
3/26/2013 2:06:52 PM - Load Config - Checking device type settings for all devices...
3/26/2013 2:06:52 PM - Load Config - Finished checking device type settings.
3/26/2013 2:06:52 PM - Load Config - Loading Events...
3/26/2013 2:06:52 PM - Load Config - 77 total events loaded.
3/26/2013 2:06:52 PM - Database - HomeSeer configuration database C:\Program Files\HomeSeer HSPRO\config\sample.mdb has been closed.
3/26/2013 2:06:53 PM - Startup - HomeSeer version is: 2.5.0.79
3/26/2013 2:06:53 PM - Startup - Starting remoting (Remote client connection monitor)
3/26/2013 2:06:53 PM - Startup - Creating Speaker Client Interface Object...
3/26/2013 2:06:53 PM - Startup - Initializing phone interface...
3/26/2013 2:06:53 PM - HSPhone - HomeSeer Phone Web Interface initializing.
3/26/2013 2:06:53 PM - Startup - Checking for pending updates to be installed...
3/26/2013 2:06:53 PM - Startup - Restoring Device Status...
3/26/2013 2:06:54 PM - Startup - Checking for available plug-ins
3/26/2013 2:06:54 PM - Plug-In - Found plug-in: X10 CM11A/CM12U, version: 1.0.1.0
3/26/2013 2:06:54 PM - Plug-In - Found plug-in: X10 CM15AUSB, version: 1.0.0.3
3/26/2013 2:06:54 PM - Plug-In - Found plug-in: DR Monoprice HDX Plugin, version: 1.2.0.0
3/26/2013 2:06:54 PM - Plug-In - Found plug-in: DR IP/Serial PlugIn, version: 2.0.4727.20476
3/26/2013 2:06:54 PM - Plug-In - Found plug-in: Global Cache, version: 4.0.0.7
3/26/2013 2:06:56 PM - Plug-In - Found plug-in: Hauppauge Capture, version: 4.1.0.2
3/26/2013 2:06:56 PM - Plug-In - Found plug-in: HSTouch Server, version: 1.0.0.58
3/26/2013 2:06:56 PM - Plug-In - Found plug-in: HSTouch Android, version: 1.0.0.2
3/26/2013 2:06:56 PM - Plug-In - Found plug-in: HSTouch iPhone, version: 1.0.0.2
3/26/2013 2:06:57 PM - Plug-In - Found plug-in: HSTouch Server Unlimited, version: 1.0.0.1
3/26/2013 2:06:57 PM - Plug-In - Found plug-in: Insteon, version: 1.1.52.1
3/26/2013 2:06:57 PM - Plug-In - Found plug-in: iTunes, version: 2.5.0.13
3/26/2013 2:06:57 PM - Plug-In - Found plug-in: Media Center, version: 2.1.0.3
3/26/2013 2:06:57 PM - Plug-In - Found plug-in: Media Player, version: 2.5.0.16
3/26/2013 2:06:57 PM - Plug-In - Found plug-in: RainRelay8, version: 1.0.0.11
3/26/2013 2:06:58 PM - Plug-In - Found plug-in: TWA_ONKYOINTEGRA, version: 1.0.1.0
3/26/2013 2:06:58 PM - Plug-In - Found plug-in: USB-UIRT Interface, version: 1.1.0.0
3/26/2013 2:06:59 PM - Plug-In - Found plug-in: UltraM1G, version: 1.1.4502.19008
3/26/2013 2:06:59 PM - Plug-In - Found plug-in: UPB, version: 1.0.2.7
3/26/2013 2:07:00 PM - Startup - Initializing Plug-Ins
3/26/2013 2:07:00 PM - Plug-In - Initializing Plug-in: HSTouch Server
3/26/2013 2:07:00 PM - Plug-In - Finished initializing plug-in HSTouch Server
3/26/2013 2:07:00 PM - Plug-In - Initializing Plug-in: HSTouch iPhone
3/26/2013 2:07:00 PM - Plug-In - Finished initializing plug-in HSTouch iPhone
3/26/2013 2:07:00 PM - HSTouch Server Unl - Register callback completed
3/26/2013 2:07:00 PM - Plug-In - Initializing Plug-in: HSTouch Server Unlimited
3/26/2013 2:07:00 PM - HSTouch Server Unl - HSTouch Server Unlimited plugin initialized.
3/26/2013 2:07:00 PM - Plug-In - Finished initializing plug-in HSTouch Server Unlimited
3/26/2013 2:07:01 PM - UltraM1G Info - UltraM1G version 1.1.4502.19008 starting ...
3/26/2013 2:07:01 PM - Plug-In - Initializing Plug-in: UltraM1G
3/26/2013 2:07:01 PM - UltraM1G Info - UltraM1G - initializing I/O ...
3/26/2013 2:07:01 PM - UltraM1G Info - Attemping initial communication with Elk M1 ...
3/26/2013 2:07:01 PM - UltraM1G Info - Updating ELK M1 internal real-time clock to 3/26/2013 2:07:01 PM
3/26/2013 2:07:02 PM - UltraM1G Info - Elk Real Time Clock reports: 03/26/2013 14:07:01, mm/dd format, 12 hour format, DST is Active
3/26/2013 2:07:02 PM - UltraM1G Info - Initial communication with Elk M1 was successful.
3/26/2013 2:07:20 PM - UltraM1G Info - Waiting for current state information to be downloaded from the M1 ...
3/26/2013 2:07:22 PM - UltraM1G Info - Download of current state information complete.
3/26/2013 2:07:22 PM - Plug-In - Finished initializing plug-in UltraM1G
3/26/2013 2:07:22 PM - Global Cache - Register callback completed
3/26/2013 2:07:22 PM - Plug-In - Initializing Plug-in: Global Cache
3/26/2013 2:07:22 PM - Plug-In - Finished initializing plug-in Global Cache
3/26/2013 2:07:22 PM - Plug-In - Finished initializing X10 interface
3/26/2013 2:07:22 PM - Plug-In - Initializing Infrared interface Global Cache (plugin config dictates port settings, see config in setup)
3/26/2013 2:07:22 PM - Plug-In - Finished initializing infrared interface Global Cache
3/26/2013 2:07:22 PM - Web Server - Local IP address (subnet) is: 192.168.0.152 (255.255.255.0)
3/26/2013 2:07:22 PM - Web Server - Web Server started on port 80
3/26/2013 2:07:22 PM - Web Server - UPNP Discovery started
3/26/2013 2:07:22 PM - Startup - Creating ASP.NET application host...
3/26/2013 2:07:25 PM - Startup - ASP.NET application host created
3/26/2013 2:07:25 PM - Startup - Start automation engine...
3/26/2013 2:07:25 PM - Startup - This version of HomeSeer is registered.
3/26/2013 2:07:25 PM - Startup - Initializing Speaker Client Interface
3/26/2013 2:07:25 PM - Speech - Listening for remote speaker connections on port 8742
3/26/2013 2:07:25 PM - Startup - Starting Event Scheduler...
3/26/2013 2:07:25 PM - Startup - Checking HTTP connection...
3/26/2013 2:07:25 PM - Web Server - Web Server authorized local login successful from: 127.0.0.1 User: rod
3/26/2013 2:07:26 PM - Startup - Updater services starting...
3/26/2013 2:07:26 PM - Startup - Starting DDNS service...
3/26/2013 2:07:26 PM - Startup - Running the Startup.txt Script
3/26/2013 2:07:26 PM - HSTouch Server - HomeSeer has started
3/26/2013 2:07:26 PM - HSTouch Server - Server is enabled for unlimited connections.
3/26/2013 2:07:26 PM - HSTouch Server - Server is enabled for iPhone/iPod HSTouch connections.
3/26/2013 2:07:26 PM - HSTouch Server - Server started on port 10200
3/26/2013 2:07:27 PM - Startup - Scripting is OK and is now running Startup.txt
3/26/2013 2:07:27 PM - Startup - HS2Sentry is disabled in Setup, sentry will not be started.
3/26/2013 2:07:27 PM - Startup - Start up complete.
3/26/2013 2:07:31 PM - Network - Speaker client connected from: 127.0.0.1
3/26/2013 2:07:31 PM - Speaker - Speaker host added, Name: hsp IP address: 127.0.0.1
3/26/2013 2:07:33 PM - Web Server - Web Server authorized local login successful from: 192.168.0.152 User: rod
3/26/2013 2:08:11 PM - Plug-In - Interface TWA_ONKYOINTEGRA is running as a trial, 30 days remaining.
3/26/2013 2:08:11 PM - TWA Onkyo/Integra - Register callback completed
3/26/2013 2:08:11 PM - TWA Onkyo/Integra - Application path: C:\Program Files\HomeSeer HSPRO
3/26/2013 2:08:11 PM - Plug-In - Initializing Plug-in: TWA_ONKYOINTEGRA
3/26/2013 2:08:13 PM - Error - In RegisterConfigLink:Public member 'link' on type 'String' not found.
3/26/2013 2:08:13 PM - Plug-In - Finished initializing plug-in TWA_ONKYOINTEGRA
3/26/2013 2:08:54 PM - TWA_ONKYOINTEGRA - Attempting to open COM11
3/26/2013 2:08:58 PM - TWA_ONKYOINTEGRA - COM11 Successfully Connected
3/26/2013 2:09:52 PM - TWA_ONKYOINTEGRA - Debug Mode Enabled
3/26/2013 2:11:13 PM - TWA_ONKYOINTEGRA - Powering up receiver
3/26/2013 2:11:13 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Code Sent(!1PWR01)
3/26/2013 2:11:19 PM - TWA_ONKYOINTEGRA - Switching Listening Mode
3/26/2013 2:12:25 PM - Warning - Timeout waiting for COM Port write to finish
3/26/2013 2:12:25 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Code Sent(!1LMD00)
3/26/2013 2:12:27 PM - TWA_ONKYOINTEGRA - Creating Dim Device
3/26/2013 2:13:31 PM - Warning - Timeout waiting for COM Port write to finish
3/26/2013 2:13:31 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Code Sent(!1DIM00)
3/26/2013 2:13:34 PM - TWA_ONKYOINTEGRA - Failed to Create Device(!1DIM00)
3/26/2013 6:01:59 PM - Warning - Timeout waiting for COM Port write to finish
3/26/2013 6:01:59 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Code Sent(!1LMD16)
3/26/2013 6:02:01 PM - TWA_ONKYOINTEGRA - Failed to Create Device(!1LMD16)
3/26/2013 6:03:11 PM - Warning - Timeout waiting for COM Port write to finish
3/26/2013 6:03:11 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Code Sent(!1LMD40)
3/26/2013 6:03:13 PM - TWA_ONKYOINTEGRA - Failed to Create Device(!1LMD40)
3/26/2013 6:04:26 PM - Warning - Timeout waiting for COM Port write to finish
3/26/2013 6:04:26 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Code Sent(!1LMD41)
3/26/2013 6:04:28 PM - TWA_ONKYOINTEGRA - Failed to Create Device(!1LMD41)
Thanks in advance for any advice.
Rod
Rod
