Hi Tom
I have a Onyko NR905
I had been using a very old version of the plugin (I did purchase a license) and things worked. I've upgraded to version 1.1.5 via the updater and now it won't connect. (I have verified the ip address, and I can access the webpage of the receiver at that IP address). This worked before, after the upgrade it doesn't.
Please let me know what to do. Thanks!
4/20/2013 3:06:29 PM - TWA Onkyo/Integra - Register callback completed
4/20/2013 3:06:29 PM - TWA Onkyo/Integra - Application path: C:\Program Files\HomeSeer HSPRO
4/20/2013 3:06:29 PM - Plug-In - Initializing Plug-in: TWA_ONKYOINTEGRA
4/20/2013 3:06:29 PM - Error - In RegisterConfigLink:Public member 'link' on type 'String' not found.
4/20/2013 3:06:29 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:06:30 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:06:34 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:06:34 PM - Plug-In - Finished initializing plug-in TWA_ONKYOINTEGRA
4/20/2013 3:06:38 PM - TWA_ONKYOINTEGRA - Receiver 1 can not be contacted, attempting to disconnect and reconnect at IP 192.168.34.6:60128
4/20/2013 3:06:38 PM - TWA_ONKYOINTEGRA - Receiver 1 at IP 192.168.34.6:60128 Successfully Disconnected
4/20/2013 3:06:38 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:06:39 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:06:42 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:06:42 PM - TWA_ONKYOINTEGRA - Receiver 1 failed to reconnect, attempting 4 more time(s) at IP 192.168.34.6:60128
4/20/2013 3:06:42 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:06:43 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:06:47 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:06:47 PM - TWA_ONKYOINTEGRA - Receiver 1 failed to reconnect, attempting 3 more time(s) at IP 192.168.34.6:60128
4/20/2013 3:06:47 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:06:48 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:06:51 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:06:51 PM - TWA_ONKYOINTEGRA - Receiver 1 failed to reconnect, attempting 2 more time(s) at IP 192.168.34.6:60128
4/20/2013 3:06:51 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:06:52 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:06:55 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:06:55 PM - TWA_ONKYOINTEGRA - Receiver 1 failed to reconnect, attempting 1 more time(s) at IP 192.168.34.6:60128
4/20/2013 3:06:55 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:06:56 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:07:00 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:07:00 PM - TWA_ONKYOINTEGRA - Receiver 1 failed to reconnect, attempting 0 more time(s) at IP 192.168.34.6:60128
4/20/2013 3:07:00 PM - TWA_ONKYOINTEGRA - Receiver 1 Attempting to open IP 192.168.34.6:60128
4/20/2013 3:07:01 PM - TWA_ONKYOINTEGRA - DEBUG MODE: Receiver 1 Command Sent(!1PWRQSTN)
4/20/2013 3:07:04 PM - TWA_ONKYOINTEGRA - Receiver 1 Error connecting to IP 192.168.34.6:60128
4/20/2013 3:07:04 PM - TWA_ONKYOINTEGRA - Receiver 1 unable to reconnect after 5 attempts at IP 192.168.34.6:60128
