New HS2 compatible version available
This topic is closed.
This is a sticky topic.
Jon, will thre be future support for the CM17a and/or CM19a, particularly, pan-and-tilt of ninjas via the CM19a?John
Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
CM17a & CM19a
Originally posted by jrfudaJon, will thre be future support for the CM17a and/or CM19a, particularly, pan-and-tilt of ninjas via the CM19a?
The CM19a is a USB transciever. I have been scrounging the necessary documentation for accessing it but USB under Windows is an entirely different beast than serial.
Are you asking for the ability for HS to transmit commands to ninjas or to receive pan/tilt commands from ninja controllers?
JonJon Ort
JonOrt@The--Orts.com
(Remove the dashes in the address, spam is getting out of hand)
Originally posted by OmanAre you asking for the ability for HS to transmit commands to ninjas or to receive pan/tilt commands from ninja controllers?
Then again, I rather have a rock-solid interface for my W800, which your plugin is now, than a flakey jack of all trades plugin.
Keep up the great work!John
Originally posted by jrfudaYes, I know there are other plugins out there that support pan&tilt, but having one less plugin to worry about would be nice.
I agree. Ninja pan and tilt would be an awesome addition to this plugin!
The W800 can receive the Pan&Tilt commands now, so adding a special device in HS to represent those commands is not hard. I would just have to get myself a ninja...
Adding receive support for the CM19a is also not terribly hard, other than getting the USB device support done.
Adding transmit functionality complicates things. Maybe some folks who have ninjas could post what they would like to see.
JnoJon Ort
Congrats. Plugin seems to be running fine. It's still attempting to create devices that already exist though, but I'm starting to think this is an HS problem not a plugin problem. How does the plugin determine whether or not a device exists before attempting to create it? Just based on housecode and unitcode? Or is it more complicated?
Originally posted by firthaCongrats. Plugin seems to be running fine. It's still attempting to create devices that already exist though, but I'm starting to think this is an HS problem not a plugin problem. How does the plugin determine whether or not a device exists before attempting to create it? Just based on housecode and unitcode? Or is it more complicated?
I have not seen the duplicate devices, but then again I did create all of mine under the new W800 (AC RF Processor) plugin.
Seems to be working fine here so far.
DS10As and KR10As are working great!
Jon, How much will the plugin be to purchase?
Here is the link to the post that solved the problem of duplicate divices for me
http://board.homeseer.com/showthread...highlight=w800Thanks,
T.
_________________________________
Staying on the cutting edge is EXPENSIVE
