Using W800 (Registered) on HS 1.7
Using X-10 palm pads, all HR12A
Quite often when sending a command with a palm pad the HS log shows multiple "X10 Received" lines with different house codes. For example, if I send an I 10 On the log will show:
X10 Received I10 (computer Work) I On
Info ...
X10 Received A10 (?) A On
Info ...
Info
X10 Received G10 (?) G On
Info
X10 Received K10 (?) K On
Info
Info
Info
Info
Info
Info
Etc
All this over the period of a few seconds.
All the same unit number, "10", and all command "On".
BUT - three (3) house codes I didn't send, 'A', 'G', and 'K', plus the correct house code of "I".
Luckily I don't have devices on A10, G10, or K10. Other times I have had devices on the house code and number that the system has incorrectly "received" and the other devices have been switched on or off incorrectly.
Any ideas on what might be causing my problems and how I can correct them?
Info ...
Info ...
Info
Info
Info
Info
Info
Info
Info
Info
Etc
