Ok so i have used my w800 for along time and it has worked great.. so great that i had a spare and got rid of it... DOH!!!!!
so i have had issues lately... no my issues personally are different...
ok so i had my garage 100% a while ago... open door.. concord 4 would trip motion and turn light on... when no motion.. then light off... if you walked through a garage door.. motion would catch ya and turn the light on...
but one day it stopped working correctly.. the off part.. i noticed this in the laundry room, master closet and garage....
now i remember a thread where people said how hey are addressing the missing off's...
well see if you can follow this...
tonight...
1. i put new batteries in my ms13a
2. set it for G16
3. pushed the off button on the motion and my light went off... light is G10 so an event did that...
4. pushed the on button and HS received the G16 on but didnt state the event for lights on... that got me confused...
even weirder is HS status page said it was on....
i was using a palm pad 100% on and off's.... did like 50 each... in different orders....
so i was thinking back of what has changed since i was solid.. and i remember getting usb to serial units ... a 2 port and 4 port edgeport...
installed my dual serial card and pci-e 1x serial card
so i put my ti103 on com 1 on mobo
w800 and ztroller on pci dual serial card
brultech and concord 4 on pci-3 1x card
got all serial ports setup and running but for w800...
acrf2 plugin cannot locate my adapter...
i changed the serial cable
plugged it into mobo and changed acrf2 plugin to com 1 (disabling ti103 plugin)
tried both ports on dual serial
nothing would work....
followed post by BobT on another thread
so im in a stump.. did my w800 bite the bullet? dont know how to test it... im going to see if i have hyperterminal but not sure what to do...
just try and connect to com10 @ 4800????
any help greatly appreciated... and if you have a spare w800 laying around let me know... or i should pony up and get a rfxcom 310 slave unit....
edited
just used hyperterminal and it said connected at the bottom.... with time going up.. but nothing on the screen.. even hitting enter a few times.... how should hyperterminal respond?
tonight...
2. set it for G16
Originally posted by BobT
View Post
edited
