David,
I updated to the version from the updater. I deleted the devices, recreated them and restarted HomeSeer.
The device string for the A/B device still is stuck on A. The selection does take place, On for A and Off for B. The device status changes to follow that. But not the string. I ran this script when it was off, then turned it on.
<pre class="ip-ubbcode-code-pre">devc = hs.GetDeviceCode("WAF AB8SS Speaker Switcher Input A/B")
hs.writelog "ab8ss test", devc & " status=" & hs.DeviceStatus(devc) & " value=" & hs.DeviceValue(devc) & " string=" & hs.DeviceString(devc) </pre>
And this is the results I got.
7/26/2003 3:20:24 PM~!~ab8ss test~!~)9 status=2 value=1 string=Input A Active
7/26/2003 3:20:36 PM~!~Device control from menu~!~)9 Off
7/26/2003 3:20:43 PM~!~Event Trigger~!~Trigger from menu (test)
7/26/2003 3:20:43 PM~!~ab8ss test~!~)9 status=3 value=0 string=Input A Active
As you can see, the status changes, but the string doesn't.
Bill
Bill
