Hey,
I have a SCM-810 for VR with multiple microphones. This thing basically will let one microphone be on at one time. It switches to the one being spoken into. On the back is a DB connector that outputs which mike is being used. This can be hooked up to a IO controller (Ocelot /SECU16 in my case) to determine what mike is open.
I want to be able to use this mike to have HS switch the speaker to that open mike. I have seen it done via a relay controller and a standard impedance matching speaker switcher. However, this thing AB8SS looks like a better fit. I am concerned however about the switching time. Has oneone else used this thing in similar ways?
