I have Harman Kardon avr-325 which has 7.1, 50w (8ohm) per channel. The two rear surrounds can be a "zone II" type of setup, which I would like to send to the ab8ss unit.
I'm looking at purchasing the following:
ab8ss (of course)
combination of two way 4" and two way 6 1/2" enclosed ceiling speakers (rated at 25w rms/50w max for the 6 1/2" and 20/40 for the 4")
My concern is whether or not the speakers, the receiver/amp, and the ab8ss will all work well together (based on the following chart:
Resistance impedance matching information:
Number of speakers selected= 1 2 3 4 5 6 7 8
Ohm load seen by amplifier= 8.49 4.98 4.13 3.96 4.05 4.27 4.85 4.92
% power to speakers= 94 80 64 50 40 31 29 20
max power internal resistors 10 20 30 40 50 60 70 80
max power speakers 156 80 53 40 33 27 29 20
max power from AMP 166 100 83 80 83 87 98 100
also, I'm not a hard core audiophile, and I'd like to get away with running one speaker in each room. Here are some questions about that:
1. How can I guestimate if one speaker will be good for a room that's a certain size, and which size of speaker I should use in which room?
2. I know the ab8ss is set up for 8 PAIRS of speakers...is there a strategic way of placing / wiring the speakers so that I can have 16 zones from one ab8ss, or should I just get a second unit, maybe placing the speakers in such a way as to be able to add a second speaker if I want to, in the future?
also, for keeping the Mrs happy, I plan on installing a manual volume control in each room. the only one i can find cost $25 each, and is made to handle a whole group of speakers. anyone know of where I can find a cheaper/simpler volume control that can handle just one or two speakers?
ab8ss (of course)
