Contacting HomeSeer This Week
See more
See less
WAF and 2.0 updater
  • WAF and 2.0 updater
    David:
    Do you know when WAF will be in the new 2.0 v1951 updater??
    Mike
    Did you not have any luck manually installing it?
    HS: 2.5.0.60
    Environment: Virtual XP as guest in VMWare Server running under Win 7
    Plug-ins: MLHSPlugin|RCS Serial Thermostat|UltraLog|UltraMon|
    Misc: 303 Devices, 313 Events, 68+ Scripts
    HSeer: 3.0.0.54
    Plug-ins: BLGData|BLRF|BLRadar|BLRandom|BLSpeech
    UltraM1G3|UltraECM3|UltraMon3|UPBSpud|Z-Wave
    Misc: 148 Devices, 116 Events, 9+ Scripts (so far, still converting)
      No, I copied all the files that I could find and modified the startup/shutdown file but got an error when I restarted HS. I do not remember the error but it came after the startup file ran. I can post it later. I double checked w/the old (1.7) files and they were both the same.
      I figured I would upgrade to release 1951 (since I am on 1948) and try again.
      - Mike
        Yup, try the latest release, as one of the prior builds did break encrypted scripts. Build 1950 corrected this problem.
        HS: 2.5.0.60
        HSeer: 3.0.0.54
          Sorry, Mike, this is on my to-do list!
          --David
            It is working
            David:
            Don't be sorry. I was just curious. Once I installed v1951 and copied all the files over from 1.7, I got it working. The only problem is now when it goes to speak the CID info, I get an error from HS. I was too tired to look into that issue so I will deal with it tonight.
            Mike
              Another Issue...
              I manually installed it and it runs with no errors. Emails are sent, but no speech when CID comes in. Log reflects that speech is executed. Speaker client is running and it speaks when tested.
              Anyone else seen this?
              Thanks!
                No problems here. However, I've been reading about a few people having issues where the speaker app and HS quit communicating. From what I've read, a restart of both apps was needed.
                HS: 2.5.0.60
                HSeer: 3.0.0.54
                  Update: I was able to get it working!! It was just a stupid mistake on my part.
                  Thanks for all the help
                  Mike
