Contacting HomeSeer This Week
See more
See less
A Cute Trick
  • A Cute Trick
    Here is a dorkly little item I thought I would pass along. By adding the following to your WAF-NetCaller-ID-Processing script, you can create an automatic link that will perform a reverse phone lookup from the Homeseer Status page.
    hs.SetDeviceString "q1", "{a href=http://www.whitepages.com/5050/search/Reverse_Phone?phone=" & s_ncid_number& ">" & s_ncid_number & " - " & s_ncid_name& "{/a>"
    Replace "q1" with whatever virtual device ID you are using for your WAF NetCaller device. Also, replace the brackets "{" with "<". I had to do this to keep the board from parsing the URL (isn't there a way to override this?)
    Only tested with HS 1.7. May not work with 2.0.
    Last edited by Gprev; August 24th, 2005, 08:35 PM. Reason: put code in code format
    Does it matter where in the script you put this code?
    Thanx
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
    No, Im from Iowa. I only work in outer space. Captain Kirk
      Location
      It needs to be in the portion of the script that is configured to run when a call is received.
      I put the above line of code in the WAF-NetCallerID-Sample-CID-Processing.vbs file, under "Function process_ncid_data(what_parameters)."
      -George
        George,
        That's a handy trick. Thanks a lot!
        Matt
          Thanx, George
            Cool idea!!
            --David
              What would be cool is if the number was NOT in your listing to then do this, otherwise I want my custom entry displayed.
              Any thoughts?
              **** Do You "Cocoon"? ****
                BSR,
                Just slip the line of code in at this location:
                   ' Example 3: Search phone list text file for
                   '			number match. Return associated
                   '			custom name and code. Based upon
                   '			return code, caller is announced
                   '			or not, depending upon time of
                   '			day.
                   ' Attempt to return custom name for caller from phone
                   ' list file
                   i_ret = find_match(s_ncid_number, s_phone_list_name, s_phone_list_code)
                   If i_ret = -1 Then
                  	' No match was found in the phone list text file.
                 	' Assign NCID name to phone list variable and
                 	' assign a code of 2000 (Others) to caller.
                 	s_phone_list_name = s_ncid_name
                 	s_phone_list_code = 2000
                 	' Add new caller to text file with a default
                 	' code of 2000.
                 	i_ret = add_caller_to_file(s_ncid_number, s_ncid_name, 2000)
                   End If
