Here is a dorkly little item I thought I would pass along. By adding the following to your WAF-NetCaller-ID-Processing script, you can create an automatic link that will perform a reverse phone lookup from the Homeseer Status page.
Replace "q1" with whatever virtual device ID you are using for your WAF NetCaller device. Also, replace the brackets "{" with "<". I had to do this to keep the board from parsing the URL (isn't there a way to override this?)
Only tested with HS 1.7. May not work with 2.0.
hs.SetDeviceString "q1", "{a href=http://www.whitepages.com/5050/search/Reverse_Phone?phone=" & s_ncid_number& ">" & s_ncid_number & " - " & s_ncid_name& "{/a>"
