Contacting HomeSeer This Week
See more
See less
'Unterminated string constant'
  • 'Unterminated string constant'
    Hello!
    Finally got around to installing WAFNetCallerID, edited the Startup and Shutdown scripts and receive this error in the log:
    8/15/2006 6:43:22 PM ~!~Error~!~Running script, script run or compile error in file: startup.txt1033:Unterminated string constant in line 18 More info: Unterminated string constant
    My NetCallerID box is connected to com 6. All of this was working with HS1.7.x.
    I am now on HS 2.1.104.
    Here is my Startup.txt script:
    ' this is the startup script
    ' it is run once when HomeSeer starts up
    ' this is a good place to default status on some devices
    sub main()
    hs.WriteLog "Startup","Scripting is OK"
    ' if speaker client is not running, start it
    if not hs.IsApplicationRunning("Speaker") then
    hs.Launch("Speaker.exe")
    end if
    ' speak
    hs.speak "Welcome to the HomeSeer" ,TRUE
    ' add calls startup scripts and function calls here
    i_ret = hs.RunEx("WAF-NETCallerID.vbh","open_ncid",")
    end sub
    I know, it's probably some simple bone head mistake but can you help me?
    Thank you!
    -Kevin
    KLS,
    This line is in error:
    It's missing the third argument.
    It needs to be:
    i_ret = hs.RunEx("WAF-NetCallerID.vbh","open_ncid","")
    -Rupp
      Originally posted by Rupp
      KLS,
      Hey Don't argue with me Rupp ....BTW, WHICH arguement?
      I entered this line exactly as the installation dialog stated (I think...). Anyhow, I am not yet a VB pro so can you shed some light on this?
      Thank you.
      -Kevin
      On-Edit: As usual - Rupp is the man!
      I seem to have dropped a " in the script line.
