Contacting HomeSeer This Week
See more
See less
Com port error
  • Com port error
    I am converting to 2.1 form 1.7 and am getting the error listed below. I did install the software that comes with the net caller id unit and it worked correctly. My usbuirt shows it is taking com 1 but that is what the older h/s 1.7 said also. It is usb after all so that should not be the problem.
    10/15/2006 4:27:20 PM - WAF-NetCallerID - Failed to open COM 1. Caller-ID disabled. Error is Error: Unable to obtain a handle to the COM port
    John
    If your USB-UIRT is using com port one then you will need to change the WafNetCallerId to use a different port.
    -Rupp
      Thanks Rupp,
      I sorta have it figured out. I hosed my WAF AB8SS install so I disabled it until I can get another code to enable both instances of the WAF AB8SS and hopefully then know what com that plugin in is grabbing.
      John
        Hi, John,
        Is there any way I can help? Did you get your codes from HST to enable the plug-ins?
        --David
          Did get another code. All is well.
          John
