Waf and remote speaker clients
This topic is closed.
    I can not figure out where I would put into the WafNetCallerID script which speaker clients to send the announcements to. If that's possible?
    Thanx
    Tim
    FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
    HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
    Hey Tim,
    Are you running the canned script or one of your own?
    I think if you are running your own script then we can point and shoot using:
    To have announcements from the HomeSeer Phone to a specific speaker application, type the host name or IP address of the computer running the speaker application and the instance name of the speaker application separated by a colon (. When the speaker application is first run, the instance name is set to "default". For example, 127.0.0.1:default.
    To have the announcement sent to all the speaker clients that are currently running (to all hosts), leave the instance blank or use an asterisk (*), such as 127.0.0.1 or 127.0.0.1:*.
    or use:
    hs.speak "Hello people in the kitchen.", True, "Kitchen:*"
    If you are just using the WAFNetCID to feed the HomeSeer Phone then under Setup / Phone you would find this:
    <table border="0" cellpadding="0" cellspacing="1" height="54" width="382"><tbody><tr> <td class="tableheader" colspan="20" align="left" nowrap="nowrap">Localization and Customization Settings:</td></tr> <tr> <td class="tableroweven" colspan="4" align="right">
    </td> <td class="tableroweven" colspan="9" align="left">
    </td> <td class="tableroweven" colspan="4" align="right">
    </td> <td class="tableroweven" colspan="3" align="left">
    </td></tr> <tr> <td class="tablerowodd" colspan="4" align="left">Speaker App Instance for Message Playback: *
    </td> <td class="tablerowodd" colspan="16" align="left">
    </td></tr></tbody></table>
    Is that close to what you are asking? Sometimes I don't read too well.
    ~Bill
      Actually Bill I am not running HSPhone. Just the NetCallerID box and the "WAF-NetCallerID-Sample-CID-Processing.vbs" script.
      My dad actually called me today and said-"Do I have to know everyone that calls your house?"
      The main reason I put this on his compter anyway was so when we are gone and a sensor goes to alert, he can investigate.
      Thanx
      Tim
        You should generate some fake calls and make your Dad think your getting calls from Donald Trump, Oprah Winfrey, Tyra Banks, etc. .
        Jim Doolittle
        My Twitter
        My Hardware & Software
          He got wound up enof when all these girls names were spoken. I am married and have 2 girls and a boy. The boys girl friend calls and the daughters friends call. So I uninstalled it for now till I can figure somethin else out.
          Tim
            Hey Tim,
            I'm confused, but that happens a lot now days (daze?). Why can't you just edit that script WAF-NetCallerID-Sample-CID-Processing.vbs if that is what you are using?
            All we'd need to do is change:
            ' Example 1: Announce name supplied by the
            ' NetCallerID unit.
            'hs.Speak "Call from " & s_ncid_name
            to
            ' NetCallerID unit.
            hs.Speak "Call from " & s_ncid_name, True, "fungun_homeseer:*"
            If you're not a scripter we'll chip in and get this going.
            Need to keep that DAF low.
            ~Bill
              My script don't look like that. Must have altered it and didn't save the original. The first "Example" I have is #3. But I did find this part futher down.--
              PHP Code:
              Sub AnnounceCaller(Data)
                  If
              Data <> "InUse" then hs.speak AnnounceSoundTRUE
              if instr(ucase(s_phone_list_name),".WAV") or instr(ucase(s_phone_list_name),"BLOCKED"then
                      hs
              .Speak s_phone_list_name
              else
                      IF
              Data <> "InUse" or Match "Found" then hs.Speak  s_phone_list_name " calling. "
              If ucase(s_phone_list_name) = "UNKNOWN NAME" or s_phone_list_name "Cell Phone" or Match "NONE" then hs.speak Replace(s_ncid_number,"xx916-","",1,-1,1)
              end if
              End Sub
              But wasn't sure about putting it here because this part follows the "Audry" section of the script.
              Thanx
              Tim
                How about you zip that puppy up and post it the way it was working for you.
                All I need it the name of the computer that your speaker client that you want to speak is running on.
                ~Bill
                  Or if you'd rather not post it, PM me and we'll swap email addresses.
                  ~Bill
                    Thank you much for looking at this for me
                    Tim
                      Sorry about the wait, they actually made me work today.
                      The changes I made are where I put this:
                      '++++++++++CHANGE MADE HERE+++++++++++++++++++++++
                      The line you need to change looks like this:
                      Fungun_Computer_name = "Put name or IP address here" 'Name of your computer
                      I'll keep an eye on the board, let me know if it works.
                      Good luck, Bill
                      ~Bill
                        Bill, Thank you much
                        Worked like a charm.
                        I owe ya one.
                        Tim
                          Glad it worked.
                          I'll bug you again when I have another ridiculous ML question.
                          ~Bill
