I had something happen out of nowhere, HS isnt getting call data. I checked phone line.OK I get data on Wafnet Box. Ok. HS log doesnt show call. On start WAFnetcallerid loads okay and finds port so I assume it is finding the box okay. Any tips?
Lost my logging info. No Announcing
This topic is closed.
ppTags: None
pp
Originally posted by Bill Brower View PostMake sure:
i_ret = hs.RunEx("waf-netcallerid.vbh","open_ncid","")
is still enabled in your startup.txt file.
Do a search for the word Hyperterminal in this message board area. Shutdown HS and get the HT working, see if data getting to computer.
OK, shut down HS.
Rename you WAFNETCid....ini file to something else.
If you have custom files that may be overwritten by a reinstall, move them somewhere safe for now.
Rem out (remove) that line hs.RunEx("waf-netcallerid.vbh","open_ncid","") in the startup.txt file.
Restart HS, reinstall the package from the updater.
Try to get it going again.
~Bill
pp
Did that already... I am starting to think it is something in the WAFNET Box which is a long shot with such a well crafted device.. lol
But It shows no signs that it isnt working other than passing the data. Do you know a way to ping or talk to the device to see if they communicate back to the PC?
Originally posted by pp View PostDo you know a way to ping or talk to the device to see if they communicate back to the PC?
Ya, that was the Hyperterminal comment above. Remember to not have HS running or it will tie up that comm port.
Read these posts:
http://board.homeseer.com/showthread.php?t=113647&highlight=hyperterminal
http://board.homeseer.com/showthread.php?t=95706&highlight=hyperterminal
Let us know how it goes, Bill
~Bill
