Contacting HomeSeer This Week
See more
See less
enter license code & other
  • enter license code & other
    Installed the plug-in, for the 1,0000000000000000000000000000000th time and cannot find any place to enter the license reg codes let alone configure the plug-in.
    This particular plug-in at one time worked beautifully however, during one of the HS upgrades, it quit working. I have installed and re-installed this plug-in about infinity-1 times. (and it just keeps getting worse...)
    I know I can edit the .ini file manually but not only am I still limited to the 30 day trial, I cannot get the thing to create and add to the "WAF-NetCallerID-Phone-List.txt" file.
    Ideas or did I throw away my $35.00?
    Thank you!
    -Kevin
    hello...
    44 reads and just crickets chirping?
      Being one of the crickets, there isn't much I can say except I haven't seen the author of this script around for a couple of years. Hopefully someone using it will be about to help you.
      Marty
      XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
      Playing with HS3 a bit but it's just play at this point.
        Setup
        Phone
        Edit Licenses @ upper right
        Go to bottom of the screen
        ~Bill
          Follow these steps:
          1) Install and configure SnevlCID (free)
          2) Restart, and get all the features you had plus lots more
          3) Relax knowing you got a couple of years for that $35
          Steve (aka Snevl)
            Originally posted by stevea View Post
            Follow these steps:
            Steve (aka Snevl)
            Thank you Steve!!
            Thank you Steve!!
            Thank you Steve!!
            Thank you Steve!!
            Thank you Steve!!
            I had to configure the SnevlCID via the .ini file because, when I opened the "Snevl_CID_config.aspx" file in the IE browser, the file opened as text only.
            How do I get the config file to open as a web page in IE?
            Is there any other way to config the thing?
            I am using the NetCallerID box on com6.
            One phone line.
            No phone books or logs created yet. How do I initially create them, what is the default configuration as far as layout? Do I need to configure them at all or will the SnevlCID do that for me?
            Please check my NCID.ini file for correct configuration:
            [Port]
            com=6
            com2=0
            [CID]
            swap_names=1
            [HSP]
            use_hs_phone=NO
            line=1
            line2=0
            [BetaBrite]
            use_snevls_betabrite=no
            [pages]
            Phonebook_page_name=KLS_CatHouse Phonebook
            Call_log_page_name=KLS_CatHouse Call Log
            [LineNames]
            line1=Home
            line2=Office
            [Phrases]
            line1=on the home line
            line2=on the office line
            [Debug]
            debug_mode=1
            [DumpCalls]
            WaveOn=1
            TtsOn=1
            dump_phrase=You're caller eye dee is not recognized, or is recognized as solicitation. We do not accept phone solicitations. Please remove this number from your call lists, and do not call back. Thank you.
            dump_wave=D:\HomeSeer 2\DATA\snevl_sit.wav
            [Database]
            auto_add_callers=Yes
            [Updated]
            ini_updated=NO
              Originally posted by Bill Brower View Post
              Setup
              Phone
              Got it!
              Thank you Bill, hopefully I will not need the WAFNetCallerID anymore.
              See Below.
                Thank you Steve!!
                I'm not sure what that could mean. If you put it into your homeseer html directory, you should be able to access it directly like any other HS page.
                Send me a PM with your email address, and I'll work with you. Sorry if it didn't work easily the first time.
                As for your phonebook and log: The log will start from empy. If you have stuff in your WAF phonebook, I can probably translate that pretty easily, if you want to send it to me. Let me know your email address and I promise to make it all work for you!
                Steve
                  Trying to clear out errors.
                  I am trying out this program, I thought I had purchased it at one time, but cant find anything in my emails.
                  I am getting a error that I would like to get cleared up before buying.
                  Running script, script run or compile error in file: WAF-NetCallerID-Sample-CID-Processing.vbs1002:Syntax error in line 8 More info: Syntax error
                  I believe I have it setup right, but not sure and always looking for help.
                  Thanks in advance,
                  danielbo
                  danielbo
                    Use the license request for on the HomeSeer support page to have your licenses sent to you if you want to see if you have a license.
                    -Rupp
