There is currently an issue with script licensing in HS 2 that is preventing users from being able to run WAPSeer 2 in its trial mode. After installing, users are immediately told that their trial has expired.
To remedy this, please do the following:
These will run without a license until 9/30/2005. (They also contain some fixes to event display and execution that will be rolled into the next release). If you purchase a license before then, it will still be properly recognized by this version.
If you have any questions, please let me know!
Justin
- Install WAPSeer 2 from the HS 2 updater
- Download the following (right-click on the link, select Save Target As and choose a save location): http://wapseer.carrotpatch.net/WS21Interim.zip
- Open the ZIP file
- In your HS 2 HTML directory (probably C:\Program Files\HomeSeer 2\HTML), replace WAPSeer.ash and WAPSeerWML.ash with the versions found in the ZIP file.
Justin
