NOTE: This thread is closed. Please use this thread for WAPSeer 3 issues discussion instead: http://board.homeseer.com/showthread.php?t=108188 . Thanks!
As most of you know, WAPSeer 3 is the compiled plug-in upgrade (as opposed to a script, like WAPSeer 2) to WAPSeer, designed specifically for HS 2. I've been working on it for quite some time, and, and... wait for it...
Last night, I finally got WAPSeer 3 to the point where I'm comfortable with labeling it "beta 1" and releasing it for you guys to play around with. The only items remaining for test are license validation related. As soon as a couple minor details related to that are worked out, I will get WAPSeer 3 into the updater for HS 2. So, without further ado:
Features Included in Beta 1
Fixes from WS 2.1 to WS 3
In Development for Future Releases of WS 3 Beta
Items No Longer Supported
Feel free to comment and discuss. Your input is very important - this is your product!
Justin
- Location View
- Device Control (On/Off/Dim/Toggle from Location View)
- Event View (By Event Group/All Events)
- Event Control (Trigger/Enable/Disable)
- QuickList (Devices w/toggle, Events w/trigger, improved interface)
- Device toggling from location view works correctly. Devices now indicate the correct state after being toggled.
- Dimming for Z-Wave devices is fixed.
- A new URL architecture that removes &s and other special characters from the URL line resolves several browser compatibility issues.
- All devices and events are now internally communicated and stored by their reference ID, eliminating problems with duplicated event names and device X10 codes.
- A new RefreshGuard feature prevents WAPSeer from re-executing a command after the browser is closed, reopened to the same location and automatically refreshes.
- WAPSeer 3 is much neater, consisting of only 2 files (HSPI_WS30.DLL and WAPSeer3.ini). No files are placed in the HTML directory.
- Performance is greatly improved thanks to the binary code and tighter cache/header control.
- Plug-in thermostats. Already in alpha, and priority #1.
- Log Viewer
- Direct X10 capability, allowing entry of an X10 code and ON/OFF/DIM command for direct execution from your mobile device.
- WMP plug-in support.
- Revised HS Phone interface, which will allow high-speed devices with multimedia capabilities to play back HSP messages directly from a link.
- Revised IR interface.
- WML Mode. WS3 will be XHTML-only. Supporting WML basically doubles development time for any given feature. Users with non-XHTML phones will have to remain on the 2.1 code. At this point, there are very few devices in circulation that do not support XHTML. I simply cannot continue supporting the two codebases while improving WAPSeer any longer.
- Compose Scenes. Users who wish to trigger Compose Scenes can set up event groups containing the scenes they wish to invoke. Compose devices will appear with Compose controls in Beta 1, but they will not function correctly. If there's a massive public outcry about this, I could be persuaded to change direction, but demand for the original feature was only driven by a couple people.
Justin
