Contacting HomeSeer This Week
See more
See less
DisplayText key not work ?
  • DisplayText key not work ?
    I'm sending BSC xAP messages to HomeSeer plugin and I wanted to send messages like
    class=xAPBSC.cmd
    output.state.1
    id=*
    state=On
    DisplayText=Open
    but homeseer devices name still show ON and not Open
    How can I do ?
    James will no doubt comment on how he manages the displaytext tag within BSC devices in HomeSeer .
    However an alternate way.. - just choose to 're-recognise' the device again but don't select the BSC option - you will then be presented with a list of all the available parameter fields in the BSC schema - choose displaytext (make sure it was present in the message you sent when you triggered the wizard) and you will be able to create a new device that reflects whatever is contained in displaytext. The original device which just shows the ON|OFF state will continue to be useable as well so you will get both shown.
    Kevin
      I'm sorry but what I'm trying to do is to change status and / or value of a standard HomeSeer device (X10, lamp module for example) by sending xAP BSC1.3 messages to HS plugin.
      I've got no problem to set the device ON or OFF with messages like :
      class=xAPBSC.cmd
      output.state.1
      id=*
      state=On
      In HS the device changes to ON and I can see my light shining.
      But when I send the message below, the device changes to ON but the "ON" text still remain in its status.
      class=xAPBSC.cmd
      output.state.1
      id=*
      state=On
      DisplayText=Open
      Thank you for your help
        The other Kevin is more the definitive source than me on BSC, but the displaytext field is an optional component of the BSC message
        I dont know if James has implemented this, but I suspect not. I am sure he will soon put us straight
        Even if he has, I know that there are possibly pitfalls in changing the HS DeviceString. For instance I had done this with a callback script from this board for some time. This was OK until I wanted to use HS's Touchscreen interface which relies on this to work out what to show
        See this recent thread (top of page 3)
        http://forums.homeseer.com/showthrea...=100724&page=3
        Kevin
          Unfortunatly the current plugin doesn't currently support the DisplayText= element in a BSC message.
          In the case of a gate which is either open or closed you could use a Text=Open or Text=Closed instead of state=on .
          One other alternative is to use the BSC message to set the state of the device and the send a homeseer.command message to change the display label. Details of the homeseer.command schema can be found here http://www.mi4.biz/modules.php?name=...howpage&pid=10
          I will look to supporting displaytext in future revisions.
          James
            Thanks James.
