Contacting HomeSeer This Week
See more
See less
xAP conduit address config problem
  • xAP conduit address config problem
    All,
    I am trying to get homeseer to talk to Xlobby (different PC) with the new plugin.
    I have narrowed the problem down that the Xap conduit on homeseer does not have its address configed properly. See below for one of the xAP conduit status messages going out:
    xap-header
    v=12
    hop=1
    uid=FF416304
    class=xAPBSC.event
    source=mi4.homeseer..116:Outside.Temperature
    output.state
    State=ON
    Text=53.8
    Its missing the field after "mi4.homeseer.".
    What did I forget to configure so it shows the PC location?
    Thanks.
    Originally posted by a0192677
    All,
    I have narrowed the problem down that the xAP conduit on homeseer does not have its address configed properly. See below for one of the xAP conduit status messages going out:
    <snip>
    Yes...as you say the xAP HomeSeer plugin hasn't picked up the windows machine name automatically which should be between the two periods in the address.
    source=mi4.homeseer.<machinename><machinename>"machinename". 116:Outside.Temperature
    I wonder, is this an oldish version of Windows you are running on by any chance ?? There isn't current a way to configure this.. looks like a way might be needed to manually define it or pick it up differently.
    K</machinename></machinename></snip>
      I am running Win98 so sounds like my problem.
      Thanks.
        Here is the VB Module I use to obtain the computer name and it works with 98/2K/XP. Winsock also provides a way to get this information.
        Public Declare Function GetComputerName Lib "kernel32" Alias "GetComputerNameA" _
        (ByVal lpBuffer As String, nSize As Long) As Long
        Public Function GetThisComputerName() As String
        ' This routine will obtain the Computers name from the system. The
        ' second time it is called it returns the static 'sName' variable
        Static sName As String
        Dim lBuffLen As Long
        Dim sBuffer As String
        Dim lRet As Long
        10 If Len(sName) > 0 Then
        20 GetThisComputerName = sName
        30 Exit Function
        40 Else
        50 lBuffLen = 128
        60 sBuffer = String$(lBuffLen, vbNullChar)
        70 lRet = GetComputerName(sBuffer, lBuffLen)
        80 If lRet < 0 Then
        ' Handle API error Here
        90 Exit Function
        100 End If
        110 sName = Left$(sBuffer, lBuffLen)
        120 GetThisComputerName = sName
        130 End If
        End Function
          Thanks for everyone's help.
          The developer upgraded the XAP_conduit to allow the computer name to be inserted in the settings file:
          http://groups.yahoo.com/group/xap_au...n/message/1260
          (need to subscribe to xap_automation)
          All is well now.
