I have read all the messages in this forum and also on the Mi4.biz site and am still stumped. I have seen similar problems but nothing I have tried is working. Because it is a stand alone application I've tried it with everything running, and with nothing else running with the same result.
I assume port 80 for the updates, both timed updates and fresh program launch.
If I delete the weather.ini file, start the app and put in the required info, it works every time just like it should. (the first time after manual entry)
Then if I let it run in the system tray, it never updates. Does it do this automatically or is there something I'm missing?
If I shut it down and restart, it always gives me a no data error, and it never even tries to connect to NASA for new data.
I have shut down my firewalls and tried with no luck. I have set permissions for wide open access to the net, just to try it, nothing gained.
If it didn't work at all it would be easier to accept! Any ideas would be welcome and appreciated.
Glen
Added 4-30-05
I'm apparently the only one having this problem. Has it worked well for all that are using it?
Glen
Added 4-30-05
