Contacting HomeSeer This Week
See more
See less
XAP level variables from HS
  • XAP level variables from HS
    Using the XAP Viewer, I see every ADIOcelot variable as a binary variable in XAP. What should I do to convert these variables and Ocelot analogue inputs to "level" variables in XAP? Must I activate the "Run as XAP node" check button in the ADIOcelot menu?
    And for conventional devices, what if I use virtual devices with level values different to 0-100%? For instance, I've created a virtual device with value 2005. In the viewer the level for this device is level = 2005/100. Does the HS XAP plugin always send level values related to the 0-100 scale?
    Thank you very much,
    Daniel.
