What should I use for these settings for xLobby?
X10 Target
X10 Secondary Target
House Codes for Secondary Target
Debug Mode noYesNo
Auto Update
Schema Check noYesNoCheck Now Last check 2/5/2006 11:52:46 AM
I'm having some issues with xLobby when using the Homeseer Interface. xLobby memory usage continues to climb until it uses up all available machine memory and locks up the computer. I don't have anything in the settings above and I'm able toggle Homeseer devices and current ststus from Homeseer. It works fine with xLobby - except for the memory issue which makes everything useless in after about 2 hours. If I moniter xLobby I get a continuous stream of messages from Homeseer with device statuses.
I'm trying to determine if the problem is within the xlobby plugin side or the Homeseer interface side. Any suggestions?
X10 Target
Debug Mode noYesNo
Auto Update
