Ok. Basic setup is OK and devices are found.
Now for the advanced stuff.
Now I want to send an xAP message from Homeseer to the RedRat Connector to trigger the RedRat to send an IR code. All my IR codes are in the signal Db and all are tested to work OK directly from RedRat software.
In xAP conduit I create an event, then a sequence OK.
Then its not so clear. There is no RedRat command in the list but there is Raw xAP. Do I need to use that?? If so then what is the format of the command that needs to be sent??
Or should I be able to define the RedRat as the Infrared Interface? Is that possible?
I can really see some great potential with this - just need to get the basics understood.
Jeff
Jeff
