Contacting HomeSeer This Week
See more
See less
No devices
  • No devices
    Hi,
    I'm running HS2 and want to experiment with a NETIOM xAP board.
    I downloaded and installed mcsxAP plugin.
    I have my Netiom board up and running, I can log onto its webpage.
    I have opened UDP 3639 on the HS PC.
    From what I had read I expected to see the Inputs and Outputs appear as Devices in HS - but I see nothing
    Is there something else I need to configure?
    This forum is for the discussion of the MI4 plugin. mcsXap forum is at http://board.homeseer.com/forumdisplay.php?f=747 Start a new thread there if you need to continue this discussion.
    There is a HS3 mcsXap manual at http://board.homeseer.com/showthread.php?t=161282. It is more oriented to novice setup. There is documentation at http://board.homeseer.com/showthread.php?t=113939 for HS2 that is oriented to setting up a 1-wire environment with mcsXap.
    Your HS2 computer needs an xAP hub running.
    There is much traffic in an xAP environment and you do want everything to automatically appear as HS devices. You use the mcsXap setup page to Accept selected messages to be mirrored as HS devices.
      Thank you
        Originally posted by IanIreland View Post
        Hi,
        Hi Ian,
        Did you get the NETIOM xAP board running? Just got mine and no luck so far. Looking for pointers on what needs to be setup.
        Mark
