My HomeSeer HS2 computer is about to fail. I have purchased a refurbished Dell windows 7 Pro, 64 bit laptop which I would like to use to run both HS2 and HS3. I have installed windows XP as a virtual machine on the laptop and I have HS2 successfully running in that environment. So far, I have not been able to get xapmcs1wire.exe to work. The xapmcshub is working and xapmcs1wire.exe is running but it will not recognize the DS9490 adapter. The Dallas 1wire viewer does recognize and communicate with the DS9490, so I know the hardware and drivers are working.
Have you or do you know if anyone else is running your xap programs on a virtual XP setup?
Steve Q
Steve Q
