Originally posted by Michael McSharry
View Post
... If you have HS/mcsXap setup to accept devices from an old computer and you want to have the same devices from a new computer then you will need to edit the source of the device in the database while HS/mcsXap is not running.[/QUOTE]
I went in and changed all the machine names all the tables in my %Homeseer Directory%\data\mcsXap.mdb from old to new, as well as in the device in the mcsXapDevices.ini file. Seemed to come up ok when I restarted HS and enabled mcsXap. Config worked, but of course the plugin is the only component installed right now. I haven't even moved the 1Wire devices over yet.
Thanks again
Gary
