How do you folks get the Ocelot to display the "Off On" status in Homeseer? ALso is there a method to invoke a CMAX based macro from HS? I am using the ADIOcelot plugin and have a simple CMAX program for a macro. The program sets a variable for #1 = 0 or 1 depending on if it is off or on. In HS the device is displayed and teh status shows 1 or 0 ( How do I make this show the correct state On Off).
What my plan is to move all macros to the Ocelot and have the status displayed in HS - ideally I would like to have HS be able to invoke the same macro buy way of the touchpad interface.
here is the CMAX code I am using to test this theroy out with:
IF X10 M/14 On command pair
THEN Transmit Single X10 B/1
THEN Transmit Single X10 B/2
THEN Transmit Single X10 B/3
THEN Transmit Single X10 B/On
THEN Variable #1 = 1
IF X10 M/14 Off command pair
THEN Transmit Single X10 B/Off
THEN Variable #1 = 0
End
End
