I'm using the Ocelot / PowerLink II with HST's Ocelot plug-in. My lighting is all Lightolier Compose including firewalls, making it quite reliable.
That said, I am noticing some mis-interpreted or partially received X10 showing up in the HS2 log. I've verified that the correct X10 messages are indeed reaching the AC receptacle into which the PowerLinkII is plugged by simultaneously logging all X10 traffic in the same location using the ACT AT004. The noise at the receptacle is also quite low (<40mV).
Earlier tonight, for example, I pressed Scene B on my kitchen CP keypad which then transmitted X10 Preset DIM 3 (or Monterey PPD) to address D10.
The AT004 tester showed that it received the correct X10 (in Monterey):
D10 -----
Ppsd0 -----
The corresponding entry in the HS2 log was this:
X10 Received D10 (Kitchen Lights) D3 (Dining Room Bookcase Lights) D Preset Dim2 17
While it should have been this:
D10 (Kitchen Lights) D Preset Dim 3
I'm not sure if the PLII, Ocelot, HST plug-in, or HS2 is the culprit. Should I try disabling HS2 for a while and use the X10 monitor in CMAX to see what the PLII/Ocelot reports? Any other suggestions?
The expensive solution (which I have a hunch would work) would be to purchase the Compose Comm card that plugs directly into the firewall. Then I would need to write an X10 plug-in to support the Compose RS232 protocol. Since the firewall is seeing/repeating the correct X10, I'd guess that the comm card would report the correct data to its serial port as well.
Don
D10 -----
Ppsd0 -----
Don
