I have setup a SECU 16I to monitor supervised inputs, J1 and J2 are installed. I using the HS plugin and have created devices in HS. The problem is that on a random bases some or all inputs will switch states from off to on with no in put to the SECU 16. I have watched in in CMAX and the inputs are steady and on switch with an input. Any advice or help would be appriciated.
Dave
Problem solved.
Dave
Problem solved.
