Missing File
  • Missing File
    I'm getting an Ocelot error because I'm missing the file AHUTIL.DLL, I tried to re-install via the updater, but the same error persists. Where can I get this file??
    Dennis
    What version of HomeSeer are you running?
    -Rupp
      2.1.104
        This file should be in the HomeSeer root directory. Have a look and see if it's there.
        -Rupp
          The only version of this file on my system is in teh old Homeseer 1 directory.
            Should I re-install HS, or can I pick this file up somewhere?
            Dennis
              a repair of your HS install should fix this. Have you tried the repair option in the add/remove programs?
              -Rupp
                Tried that, didn't work. Can someone just send me the file??
                  Here you go.
                  -Rupp
                    Same problem with new installation of HS 2.1.122.0 the file is missing.
                    Downloaded the file and problem solved.
