Missing File
    Missing File
    I'm getting an Ocelot error because I'm missing the file AHUTIL.DLL, I tried to re-install via the updater, but the same error persists. Where can I get this file??
    Dennis
    What version of HomeSeer are you running?
      2.1.104
        This file should be in the HomeSeer root directory. Have a look and see if it's there.
          The only version of this file on my system is in teh old Homeseer 1 directory.
            Should I re-install HS, or can I pick this file up somewhere?
            Dennis
              a repair of your HS install should fix this. Have you tried the repair option in the add/remove programs?
                Tried that, didn't work. Can someone just send me the file??
                  Here you go.
                    Same problem with new installation of HS 2.1.122.0 the file is missing.
                    Downloaded the file and problem solved.
