all of a sudden HS has lost the ability to interact w/ my ocelot. i have a secu-16, secu16ir, and rly8xa. when i load cmax it connects fine. close cmax, load hs, it thinks everything is fine, but none of my modules respond. the only thing i changed in hs recently was to add the waf net caller id script plugin and the vehicle mileage tracker plugin script. any clues?
HS can't interact w/ocelot, cmax can
This topic is closed.
Plugins:
BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.Tags: None
in case it matters, i'm running the .net beta of the pluginPlugins:
only one of them (waf netcallerid) uses a com, and it is set up on port 8, nothing shows up in the log as being a problem w/ either plugin. I installed the newest version of cmax, it wanted to load something onto the controller, and now I think i will need to readdress the modules, not sure yet.Plugins:
Are you sure? How does HS communicate with the Ocelot?
Originally posted by completelyhis View Postonly one of them (waf netcallerid) uses a com, and it is set up on port 8, nothing shows up in the log as being a problem w/ either plugin. I installed the newest version of cmax, it wanted to load something onto the controller, and now I think i will need to readdress the modules, not sure yet.Don
Hs connects to the Ocelot via com3. the plugin i added recently connects to the netcallerid box via com8. i've not noticed anything in the startup logs regarding either plugin not being able to connect to the devices. when i close hs and start cmax and connect via com3 to the ocelot. after updating the software on the cmax, it doesn't recognize the modules when i connect to it. i can only assume that because both cmax and HS communicate w/ the modules via the ocelot, i'll have to readdress them. i'm still waiting to hear from Guy at the ap digital forum, though, to confirm that.Plugins:
yeah...they're good fun, when they work!! Guy just said that i shouldn't have to readress them, just power cycle the ocelot. we'll see how that goesPlugins:
