I've set up an event based on the IR/Match trigger for turning on a TV with the action to turn off a light. I point the remote at the IR window on the Ocelot and press the button for turning on the TV and Ocelot X-10/IR red LED lights up so I'm assuming it is receiving the signal, but Homeseer does nothing. The log doesn't say anything happened. Is there something special I need to do so Homeseer "sees" the IR commands? I'm using the Applied Digital Ocelot plugin by the way. This is just a test, naturally. Eventually I'd like to set up some powermids for input, but if Homeseer can't recognize the signals then this won't work.
