Is there a way to make the IR hex obtained from remotecentral repeat a few times when putting it in IRMax?
I am trying to get a discrete OFF code for my Sony Pearl. Thought I might try getting the hex codes from Remotecentral and using IRMax to input them. So far seems ok and pretty easy except it doesn't work. I thought I saw a post somewhere about the length of Sony commands. I noticed the one I got from remotecentral is only about 43ms and seems to be only one sequence. If I look at the Toggle On command (that I "learned"), it is 273ms, repeats 5 times with a little somethin' somethin' at the end.
