10K Thermisistor Input to SECU-16
  • 10K Thermisistor Input to SECU-16
    Has anyone used a 10K thermisistor as an analog input for SECU-16 input expansion module?
    The simple approach would use a voltage divider (10K precision resistor in series with 10K Thermisistor across 5v source) as an input.
    The temperature range I am interested in is only 30F so linearity isn't an issue but drift could be.
    <> Is there an IC which put everything on one chip?
    <> Is there a constant current source which will give more precise current through the voltage divider?
    Rick Marron
