secu16 relays for 24vAC?
  • secu16 relays for 24vAC?
    I know that according to the information here:
    http://www.appdig.com/Secu16/secu16.html
    the secu16 relays can do .5 amp DC, but what about 24vac at .5 amp? Someone told me I could use the secu16 to function as a thermostat, replacing the RGYW wires, but i'm pretty sure those are AC, not DC.
    Ian
    Plugins:
    BLLogMonitor, BLGarbage, BLBackup, BLOutGoingCalls, BLUps, BLRfid, JvEss, DooMotion, Applied Digital Ocelot, AC RF Processor, UltraMon, PJC AVR 430, UPB, Rain8net, DSC Panel, JRiver Media center, Windows Media Player, SageMediaCenter, SnevlCID, MCSTemperature.
    I have personally found that the Secu16 relays a bit weak for most things, I use the secu16 with external relays to control most things including my heating system.
    JMHO.
    StevenE
    Why oh why didn't I just leave things alone, they had been working.
      what would you suggest?
      Plugins:
        Here's an interesting web site. I have no experience, but they look interesting.
        HS3 Pro Edition 3.0.0.548
          Mike,
          I looked at this one
          http://www.controlanything.com/Merch...T_RELAY4_RS232
          Am i reading it right? does it say it will switch up to 110vac, or is that something else? My problem seems to be the "inductive load" issue.
          Ian
          Plugins:
            ordered the rain8net, going to give it a try, after talking with the wgl guy on the phone, he seems confident it will handle the inductive load. i'm only about 75% confident, but i'm also 95% confident the inductive load is only on the dampers and not on the thermostat connections, so i will be able to use it at least for that.
            Ian
            Plugins:
              I know you already ordered, I usually just use the Elk 912 relay's connected to the secu16.
              They are cheap and easy to wire to the Secu16.
              http://www.smarthomeusa.com/ShopByMa...2/?adwatcher=3
              StevenE
                and they are ok to use on 24vac inductive?
                Plugins:
                  Just get a bigger relay from Radio Shack that has a 12VDC coil and strong contacts and run your HVAC through that. I can help.
                  ~Bill
                    I read 240 VAC, 24 VDC, 5 A. Where does your inductive load come from? What exactly are you trying to switch? It sounds like a motor of some sort.
                      yup motor in hvac dampers. 17 of them, then i need 3 24vac non inductive relays, to call for heat/fan/cool
                      Plugins:
                        I know i let this thread sit for a while, but I'm looking to *actually* to hook up my secu16. For me to switch 24vac, 500mAh, which of these would I need?
                        This is the one I'd like to use:
                        http://www.radioshack.com/product/in...odsInSession=1
                        if not, what about this:
                        Ian
                        Plugins:
                          check out this place for relays. I bought a bunch of extras when I needed relays. The price is usually pretty good.
                          Stuart
                          http://www.allelectronics.com/make-a.../Relays/1.html
                            If you already have an Ocelot setup in your system, why not just use an RLY8-XA relay unit?
                            I have one of these units and they have heavy duty Potter-Brumfield relays installed in them (contacts rated for 120 volts at 10 amps).
                            **** Do You "Cocoon"? ****
                              Ian
                              I use these from Radio Shack. I have several in use now for almost 10 years and they work great.
                              Never had a failure.
                              Gary
