Routing from HomeSeer to SECU-16IR
  • Routing from HomeSeer to SECU-16IR
    Is this the correct way to progam the Ocelot to route IR commands from the IR page in homeseer out a zone on the 16IR?
    0027 - IF Receive IR IR #14, from Ocelot //
    0028 - THEN Module #1 -SECU16-IR, IR Zone #15 IR IR #14 //
    0029 - IF Receive IR IR #15, from Ocelot //
    0030 - THEN Module #1 -SECU16-IR, IR Zone #15 IR IR #15 //
    0031 - IF Receive IR IR #16, from Ocelot //
    0032 - THEN Module #1 -SECU16-IR, IR Zone #15 IR IR #16 //
    0033 - IF Receive IR IR #17, from Ocelot //
    0034 - THEN Module #1 -SECU16-IR, IR Zone #1 IR IR #17 //
    0035 - IF Receive IR IR #18, from Ocelot //
    0036 - THEN Module #1 -SECU16-IR, IR Zone #1 IR IR #18 //
    It doesn't seem to be working for me...
    Ocelot Log file
    Here is a copy of what I get in the ocelot.log file when I push a Send button on the IR page:
    11/23/2008 9:06:08 AM Rcv data: b0= 252 b1= 1 b2= 1
    11/23/2008 9:06:08 AM Comm byte count: 0
    11/23/2008 9:06:11 AM Comm byte count: 0
    11/23/2008 9:06:11 AM Comm byte count: 3
    11/23/2008 9:06:11 AM Rcv data: b0= 252 b1= 1 b2= 1
    11/23/2008 9:06:13 AM Comm byte count: 0
    11/23/2008 9:06:14 AM Comm byte count: 3
    11/23/2008 9:06:14 AM Rcv data: b0= 252 b1= 1 b2= 1
    11/23/2008 9:06:14 AM Comm byte count: 0
    11/23/2008 9:06:16 AM Comm byte count: 0
    11/23/2008 9:06:26 AM Comm byte count: 0
    11/23/2008 9:06:28 AM Comm byte count: 3
    11/23/2008 9:06:28 AM Rcv data: b0= 253 b1= 0 b2= 0
    11/23/2008 9:06:28 AM Comm byte count: 0
    11/23/2008 9:06:31 AM Comm byte count: 0
    11/23/2008 9:06:31 AM Comm byte count: 3
    11/23/2008 9:06:31 AM Rcv data: b0= 253 b1= 0 b2= 0
    11/23/2008 9:06:34 AM Comm byte count: 0
    11/23/2008 9:06:34 AM Comm byte count: 3
    11/23/2008 9:06:34 AM Rcv data: b0= 252 b1= 2 b2= 1
    11/23/2008 9:06:37 AM Comm byte count: 0
    11/23/2008 9:06:38 AM Comm byte count: 3
    11/23/2008 9:06:38 AM Rcv data: b0= 252 b1= 2 b2= 1
    11/23/2008 9:06:38 AM Comm byte count: 0
    11/23/2008 9:06:40 AM Comm byte count: 0
    11/23/2008 9:06:44 AM Comm byte count: 0
    11/23/2008 9:06:50 AM Comm byte count: 0
    11/23/2008 9:06:57 AM Comm byte count: 0
    11/23/2008 9:06:57 AM Comm byte count: 3
    11/23/2008 9:06:57 AM Rcv data: b0= 252 b1= 23 b2= 1
    11/23/2008 9:07:00 AM Comm byte count: 0
    11/23/2008 9:07:18 AM Comm byte count: 0
    11/23/2008 9:07:20 AM Comm byte count: 0
    11/23/2008 9:07:26 AM Comm byte count: 0
    11/23/2008 9:07:34 AM Comm byte count: 3
    11/23/2008 9:07:34 AM Rcv data: b0= 253 b1= 0 b2= 0
    11/23/2008 9:07:34 AM Comm byte count: 0
    11/23/2008 9:07:37 AM Comm byte count: 0
    11/23/2008 9:07:39 AM Comm byte count: 0
    11/23/2008 9:07:49 AM Comm byte count: 0
    I can see the Ocelot from where I am pushing the button and when I send the command from HomeSeer the Comms leds on both the Ocelot and the 16IR light bright (as opposed to the dim flashing it normally does) as if the command is being recieved but no action is taking place. I can go into C-Max and transmit the remote IR no problem turns the stero on everytime. Just can't do it within HomeSeer.
      The inabiliity to have detected ir recognized by hs was one of the min reasons I wrote ADIOcelot. The is a check boxsetting on the setup of the plugin to enble the Ocelot to send recognized IR events back to hs via the serial link.
