New IR Codes being sent to all zones
    I just put some new codes for my TV into the Ocelot for use with the secu16ir and when I send the commad, either with cmax or with Homeseer. I realize that this isn't a HS problem but I posted this on ADI forum and so far I haven't heard anything back from them, so I figured I would ask here. Does anyone have any idea what happened?
    Also, can Homeseer use two different types of IR equipment, ie. the Ocelot and the Global Cache?
    Thanks.
    When adiocelot sends ir it selects a specific zone and ocation soo for it to happen the software would need to send 16 commands to get to 16 zones. Once a command gets inside secu16ir then it is pssible to fan out, but this seems like a failure mode rather than normal. A more likely scanario is that the ir signal is sufficiently strongto reach multiple zones. HS supports only 1 IR interface directly. With mcsxap plugin this can be expanded, but you would need to setup xap environment.
