Control 2 Ocelots with Homeseer.
  • Control 2 Ocelots with Homeseer.
    Is it possible to control 2 ocelots with Homeseer.
    I want a complete seperate setup from my existing Ocelot but still want to monitor / control with HS.
    StevenE
    Why oh why didn't I just leave things alone, they had been working.
    xapmcsADIOcelot is the generalized multi-unit solution. The other approach that should work is to do ADIOcelot for one and the HST Ocelot plugin for the other.
      Michael Thanks for the reply, I have tried using xap a couple of times but for some reason I seem unable to get it to work.
      I read through all the xap stuff, but I just don't see anything updating in HS. I will give it a try again.
      Otherwise I already use the ADIOcelot plugin, so I can try the newer .net HS Ocelot plugin if needed.
      Steven
        Another thing that could be done is to recompile ADIOcelot with a new interface name and load it as a second plugin.
          Would that be hard to do ?
          Thanks StevenE
            This should be the same as the existing ADIOcelot, but the name is ADIOcelot2 and the setting.ini group is hspi_ocelot2. I believe it comes up in default of Interface name "Applied Digital Ocelot" and you will need to make the selection to use the ADIOcelot2 as the Device .Interface property. An HS restart after the inteface name is changed is likely prudent. Obviously do appropriate backups before trying.
              Thanks Michael,
              I will give it a try this weekend.
              StevenE
                Michael,
                I dropped it in the HS directory and restarted HS and got these errors.
                9/21/2009 6:13:46 PM ~!~Plug-In~!~Found plug-in: ADIOcelot2, version: 1.14.0.10
                9/21/2009 6:13:46 PM ~!~Info~!~HS Compatibility, cannot access plug-in HSPI_ADIOCELOT2.HSPI ActiveX component can't create object
                9/21/2009 6:13:46 PM ~!~System~!~Registering hspi_ADIocelot2.exe with Windows
                9/21/2009 6:13:48 PM ~!~Info~!~HS Compatibility, cannot access plug-in HSPI_ADIOCELOT2.HSPI ActiveX component can't create object
                9/21/2009 6:13:48 PM ~!~Error~!~Unable to access plugin: hspi_ADIocelot2.exe, try reinstalling plug-in
                Ocelot is not hooked up yet, that will be this weekend.
                SteveE
                  I forgot to change the project name. Try the attached.
                    I know get this message.
                    9/21/2009 6:50:17 PM ~!~Plug-In~!~Found plug-in: ADIOcelot2, version: 1.14.0.10
                    9/21/2009 6:50:17 PM ~!~Plug-In~!~Found plug-in: ADIOcelot2, version: 1.14.0.12
                    9/21/2009 6:50:17 PM ~!~Error~!~Could not add ADIOcelot2 to the plug-in list. Is this a duplicate? Check for two plug-ins with the same plug-in name.
                    9/21/
                      The .12 is the correct one. It may be a registry thing. Try a hs restart. You can also trying to temporily remove the original adiocelot then put it back when the new one is recognized
                        I don't have time to try this for a couple of weeks but wanted to let you know there is at least one more person interested in the same thing. Thanks for working on this.
                        James
                        Running HS 3 on Win10 .
                          Just out of curiosity - What is the reason for 2 Ocelots?
                          A Person is Smart. People are Dumb, Panicky Dangerous Animals.
                          1,500 years ago, everybody knew that the Earth was the center of the universe.
                          500 years ago, everybody knew that the Earth was flat.
                          15 minutes ago, you knew that humans were alone on this planet.
                          Imagine what you’ll know tomorrow.
                          TLJ in MIB
                            I restarted HS after each step.
                            If I load hspi_ADIocelot.exe all appears to work well, after i renable in setup.
                            If I remove the file hspi_ADIocelot.exe and then add hspi_ADIocelot2.exe, 2 seems to initialize and has this error in log.
                            9/21/2009 7:20:07 PM ~!~Info~!~HS Compatibility, cannot access plug-in HSPI_ADIOCELOT2.HSPI Automation error
                            The system cannot find the file specified.
                            I went into the ADIocelot2 config, changed the com port and the instance to 2 hit update.
                            I then added the orig back hspi_ADIocelot.exe
                            Now ocelot 2 inits but ocelot1 does not and I get this error again.
                            9/21/2009 7:25:00 PM ~!~Plug-In~!~Found plug-in: ADIOcelot2, version: 1.14.0.10
                            9/21/2009 7:25:00 PM ~!~Plug-In~!~Found plug-in: ADIOcelot2, version: 1.14.0.12
                            9/21/2009 7:25:00 PM ~!~Error~!~Could not add ADIOcelot2 to the plug-in list. Is this a duplicate? Check for two plug-ins with the same plug-in name.
                            And a message ocelot2 cannot communicate with the ocelot ( not hooked up yet )
                            StevenE
                              I have a work shed on my property I would like to control some things in. I want the ocelot to run independent, so nothing I do purposely or other affects the house or vice versa. But I still wanted to be able to monitor things from the house.
                              StevenE
