Ocelot & Powermid
  • Ocelot & Powermid
    I have read a number of threads on this topic and understand that I can connect an IR emitter from the Ocelot to one of the Powermids and put the other Powermid near my HT equipment for full control via Homeseer.
    However, what if I want to be able to route my remote control through Homeseer so I can incorporate events, etc? I would think I would need some sort of 2 way communication. In other words, what would go in place of the "???" in the following diagram? (remote control -> ??? -> Ocelot -> HS -> Ocelot -> Powermid -> HT equipment)
    Thanks in advance.
    I've not tried this but couldn't you just reverse the install of the Powermids. In other words, put a powermid "receiver" where the remote will be, and put the powermid "transmitter" near the Ocelot. The only issue I can think of is if you get into an ir loop where one powermid sends the code the other picks it up and sends it back, etc.
    -Rupp
      For awhile I was using IR/HS/Ocelot in the manner you are asking about. In essence I was using the ocelot to translate IR so the proper equipment was controlled with the proper code. The Harmony now does this for me.
      The problems that I experienced were latency and dealing with repeating IR codes such as Volume control.
        Look at my thread on Applied Digital forum.
        http://www.appdigusers.com/forums/ub...1467#Post21467
        Unfortunately I had to put this project on back burner.
        BTW the Powermind receiver doesn't have input (at least my doesn't). Only the transmitter has output.
        A Person is Smart. People are Dumb, Panicky Dangerous Animals.
        1,500 years ago, everybody knew that the Earth was the center of the universe.
        500 years ago, everybody knew that the Earth was flat.
        15 minutes ago, you knew that humans were alone on this planet.
        Imagine what you’ll know tomorrow.
        TLJ in MIB
          The input to Powermind is an IR emitter from Ocelot (or distribution block) stuck to the unit or at least within line of sight.
            Oh, OK. When I hear input, I picture a hole...
            TLJ in MIB
