Ocelot issues in HS 2.5.0.20
  • Ocelot issues in HS 2.5.0.20
    I've noticed that since I've upgraded to HS 2.5.0.20, sometimes when I restart Homeseer, it won't respond to IR input from the Ocelot. I'm using the standard HS plugin with the Ocelot.
    I've turned on serial debugging, and I can see that the Ocelot is recognizing and sending the IR code to Homeseer, but nothing happens. The events that rely on IR triggers never fire. Oddly enough, the Ocelot is my PLC/X-10 interface as well, and Homeseer recognizes received X-10 signals fine.
    The only fix is to disable the IR interface via the web page, then re-enable it. No other change necessary.
    Anyone else with an Ocelot seeing this?
