I decided I needed IR control as I build out my HS system in the "new" house (been here 2.5 years). I used my Ocelot and the ADI Ocelot plugin in the past, but for the life of me I can't remember how I set it up and I can't find documentation that helps. Hoping someone can direct me, please...
I used CMax to learn IR codes, and when I send those codes using CMax things work fine. But after installing and enabling the InfraRed function using Setup>Interfaces, nothing worked. I then went to the IR Signals page and one by one entered the same devices and functions from CMax onto this page, and then I tried the Learn function for each. Still didn't work (even though I used the same numbering scheme in both HS and CMax, just in case)...
I closed HS and fired up CMax again - still works fine. Tried HS again (after closing Cmax down). Nada... I then disabled ADI Ocelot and tried the regular HS Ocelot plugin. It was even worse, as HS just hung when I pressed the "Send" button. I could go to the Status page and that stopped the hang, but it still didn't work. I also tried setting up an event using the drop down IR signal for something I know works fine in Cmax, but the event does nothing in terms of IR.
So... I am very, very stumped. What am I missing here, gents? HS seems to not even know the Ocelot is there... Any ideas?
Thanks in advance,
Joe
Thanks in advance,
Joe
