I recently got an Ocelot, hooked it up, programmed it via CMAX etc. I informed HS about my new Ocelot and all was well. Everything was working as I had expected. Now, I decided to try IR emission from HS through the Ocelot. I read the help file and found a small group of sub calls, something to the effect of &cpuxa.PlayIR( 1 ) for instance. When I try to run this method, I get an error stating the Ocelot is not initialized or setup correctly?? I taught my Ocelot all my IR codes seperate from HS thinking I could simply use the above sub if I knew what IR I wanted to broadcast. Is this not the case? Any help would be greatly appreciated. I am new to VB scripting, but not programming, so even a small sample script would maybe help.
Thanks in advance.
Derek [img]/infopop/emoticons/icon_confused.gif[/img]
Thanks in advance.
